Originally Posted by
thecrazyezel
I got one of these for my son and it worked fine out of the box but then started to just lose signal. At first I thought this was a fluke but it did it two other times and then it would not bind. A friend also got one and his eventually encountered the same problem today. So we have had two now experience the same issue in two days. Has anyone else had the same problem with the combined ESC/Receiver?
Hi,
I have similar problems with 2 cars I bought recently. When powering the car on, instead of beeping and the LED to light on, the servo moves shortly (always in the same direction), and nothing else happens. LED stays off, no beeps, nothing works. Is that the problem you had ? Did you find a solution ?
