I've been thinking about it also. I'm mostly concerned with getting it all together before the gorilla sets off and starts foaming.
The ailerons are 29" long with 4" cord at the inner and 2.75" outer and run full length as I'm not using tipped wings or stabs. Right now I'm spaced at 4" spacing on the ailerons and 3-3.5" on the elevators. Elevator LE are just over 15".
What kind of spacing do you guys use?
Fuse wt is 776g as it sits right now. Doesn't have the top line foam attached yet.
Hi rm,
I'm away at work at the moment and won't be home untill Wednesday. I can't remember the spacing dimensions, but I use 5 CA hinges on each aileron, 4 on each elevator and 4 or 5 on rudder. I've never had a problem with that.
CA hinges make it easy as they are assembled and aligned dry before gluing.
