RCU Forums - View Single Post - Cadence - F3A Prototype
Old 01-11-2016 | 05:16 PM
  #37
rm's Avatar
rm
My Feedback: (27)
Fitting the motor.
Header is a flex header 50mm drop. wt 107g
I measured 12.5" header length along with 16 7/8" on the pipe, so gives me a total length of 29 3/8", so prob 29.5" with spacing, without modifying anything. I'm gonna try it at that since I've been running my motors at 29" and that's pretty close. Will only have to run with 1 of Matt's super couplers. Can always shorten it later.
Ignition is a nice design. Comes with rubber isolator mounts similar to a servo. wt is 87g naked. You insert your own wires similar to a servo wire into a rx, so your wires can all be made to custom lengths.
Spinner backplate spacing came to 3/16". I'll add a 1/8" ply ring taken from the backplate, so I'll have a perfect sanding marker for the front end and end up with 1/16" spinner clearance.
ID:	2140961   Click image for larger version
ID:	2140962   Click image for larger version
ID:	2140963   Click image for larger version
ID:	2140964   Click image for larger version
ID:	2140965   Click image for larger version
ID:	2140966   Click image for larger version
ID:	2140967   Click image for larger version
ID:	2140969   Click image for larger version
ID:	2140970   Click image for larger version
ID:	2140971   Click image for larger version
ID:	2140972   Click image for larger version
ID:	2140973   Click image for larger version
ID:	2140974   Click image for larger version
ID:	2140975   Click image for larger version
ID:	2140977   Click image for larger version
