RCU Forums - View Single Post - another esc motor matching question
Old 01-12-2016 | 08:22 PM
jester_s1
Moderator
Looking at the specs for the recommended motor, you probably need to go up to a 12 amp ESC. You probably won't actually draw that hardly ever, but a little headroom is good to prevent overheating. It will also allow you to go up on the prop a little if you decide that the recommended power system is just a bit too weak for you.
