RCU Forums - View Single Post - Begginner guide?
Old 01-13-2016 | 06:51 PM
  #58
Dusty Steppes
Don't quote me on this but I think if the smoker switch is located under the radio operator's hatch next to the power switch and the volume control is under the driver's hatch you have a newer version. The steering issue can be caused by too much tension on the tracks. I have also noticed that 3 shaft gear boxes have a more sensitive steer than 4 shaft. A light touch on the stick also helps to reduce sensitive steering.
