Begginner guide?
#151
I doesn't mean it has to be a programmeable computer TX that talks back to you, it can be a simple 2 channel car Tx, but one that can be used however you want, not just what the maker decided.
It sounds like it's nit picking, but it really isn't. With a HL radio or even a high end Spektrum 2.4 that comes with their bind and fly stuff, you can't go with adding a servo recoil, etc.
In the past ten years, Tx/Rxs have become so cheap, it's amazing. You can get multichannel setup for pennies, and when you're talking tanks, not a 50 pound plane that will be flying a half a mile away, you're safe with the cheaper ones since no one is going to get killed if it browns out.
I just bought a second DX6i because I was running out of space (10 models on each) and I would have gone with a Orange box 6 channel, but the with the shipping, it was the same as the new sale prices on the DX6 ($110). I must have 25 $10 Orange Box Rxs in the shop, I use them in everything and they work flawlessly. Again, not counting on a mile range and perfectly reliability. I wouldnt use them in a $5000 plane, but in a tank, they are golden.
#152
As one Jeff to another Jeff, I thought my explanation was easier but I'll give it to you.
Jeff
#153
Steve, this is one of the "cheap radios'.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
But I recommend you go one step up to the HK6S, just because you don't have to plug into a PC to reverse servos. This one
http://www.hobbyking.com/hobbyking/s...x_Mode_1_.html
