RCU Forums - View Single Post - Painted wing, stabs and advanced graphics
Old 01-14-2016 | 10:25 AM
  #193
Portlandflyer
Originally Posted by scratchpc7
Well, you can bet that I am reading it. and learning a bunch as well.
As far as the painting for me, well, that is pretty much it. Have a top flite sea fury, that technically someone else painted for me,but the way i wanted it. It is in RAF colors. but no rivets, panel lines, etc, just the way I wanted it. there is at least one scale stickler in my club that his first words will be, "the panel lines are missing". Second is my first painting attempt that went on an R140 Q500 plane. I used the auto air colors on it, plus a single stage clear. Learned an important lesson, don't wet-sand water based paints. So I am going to call this my Shabby Chic plane. plus all of the things I learned not to do, and how to do them better in the future.
I have an auto paint store within 30 miles that has the auto air paints, and supposedly I can get the wicked colors from hobby lobby or michael's so will be able to practice some with them as well. I have shot the pearl white auto air, and i love the way in shimmers in the light.
Here is the wording from auto air on their aluminum, which is why I think masking over it will be a problem.
Aluminum Bases are sensitive to touch. Do not wipe clean or scuff after painting as any direct contact will create visible streak marks in the final finish due to the aluminum flakes being bent & crushed when wiped. The aluminum flakes are brilliant but are much different to work with compared to Auto Air 4300 Series silvers. Applying a clear top-coat or candy mid-coat is recommended soon after Aluminum Bases have cured. Apply 4004 Transparent Base or 4030 Auto Air Inter-Coat if extended time is planned before top-coating as inter-coat will protect from direct contact when cleaning prior to clear.
Doug,
Actually what they are saying applies to any sliver. It's not a sticking issue, rather like they say, more an issue of damaging the silver surface. I deal with it too with HOK. What I do is on the areas I paint black, you don't have a problem, but the areas that are left silver can have blemishes. What I do in my final touch up is just re mask those areas and shoot a light mist of silver (Metalume) over it to clean it up. One other thing you can do that will stop that is to shoot their 4030 Inter Coat clear over the silver. Inter Coat clear is just carrier with no pigment in it. HOK Inter Coat is SG100. I buy it by the Quart.
Even with HOK Metalume I have to let it set about 30 to 40 minutes before I mask over it, or it will leave masking marks.
I still think you will be fine with the Auto Air silver. Just give it lots of dry time.
I really like Wicked too. Very nice paint. I would change over to a water base, but I have a lot of working knowledge with HOK and I own a bunch of it, so I stick with it.
