Originally Posted by
Crius
Ha Ha! If only it were that simple. Swapping the turret will make you IR compatible with stock Taigen or Heng Long IR tanks, but to be Tamiya compatible is a whole different story. For that the turret swap is only the start, because that's the fastest way to get barrel recoil, muzzle flash and the base for the apple, even though you'll change that if you use a Tamiya or Impact apple. You'll have to upgrade to an aftermarket board, like an IBU2, Asp or TK22. Who are you going to have IR battles against?
I was just going to battle with wife or grandkids... not looking like it will be worth doing it... I might actually just sell or take this Tiagen back if they will let me and get a Heng Long to paint up for display and casual use - I know this one is better and all but I just don't foresee myself putting the kind of cash and effort into this hobby it would seem to require as I have other hobbies that have a higher priority for me and it seems at every turn it's more cash and not in small amounts to do much with this... not what I thought I was getting into when I bought the more expensive tank as I figured most of it would be at or near top grade and not need things like gear boxes, sound systems, new boards, new turrents etc etc... to get it where I thought it would be out of the box. I realize one can stop at any point but just to get this tank how I would like it to be is more than I want to spend on the hobby. I thought I knew after talking here but I guess I should have asked more questions - or I should have waited to use on in person rather than just looking at one and picking it up not realizing it was going to cost a ton more.. but oh well, ya live and you learn. Maybe if Erik will swap me for an IR version if I buy a new IR tank from him I could salvage things a bit? if not I doubt the hobby store will take it back as they said basically once the battery is plugged in and everything is unpacked you cannot return it... what would be a fair price to ask for a tank like that used about 10 minutes? I never used the smoke stuff at all.
