Originally Posted by
patrnflyr
"Decent scale" meant something that could handle small turbines. Frankel's Lear was made for OS91 ducted fans.
A couple of K-45's would work out beautifully in the frankel Lear jet. They are just under 3 inches in diameter.The frankle design was kind of on the heavy side anyway so 18 pounds of thrust wouldn't hurt it.
$1,650.00
KingTech G series, a true Fuel Start turbine, will start and run on Diesel, Kerosene and JetA. G series have both solenoid valves built into the front cover, with a single fuel feed that eliminates at least 8 fuel connections upstream to the turbine, making a clean engine install a very simple task.
KingTech K-45G turbine engine, made in Taiwan
Specifications:
Diameter: 76mm (2.99")
Length: 195mm (7.68")
Weight: 700g (1 lb. 8.6 oz. )
Max. RPM: 162000
Thrust: 4.5 kg @ 15° C ( 9.9 lb @ 15° c )
EGT: 700°C max
Fuel consumption: 155 g / min ( 5.46 oz / min )
Fuel: Diesel, Jet A1, Kerosene
Lubrication: 5%
Maintenance cycle: 25 hr USD300
K-45G Engine Test by Radio Control Jet international Magainze Aug/sep 2015
