Corporate jets?
My Feedback: (7)
I know about the Pilot RC and FEJ, but are there any decent scale corporate jets like a Citation out there for turbines? I've seen the video from Europe of the Citation CJ2 that was beautiful but haven't heard of any kits. I guess you need to be a scratch builder to get one of these.
From: Hamilton, Scotland & La Roche Bernard, France
Depends what you mean by "decent scale"
there's this.. http://aviation-design.fr/?rc-jet-model-falcon-7x
I'm guessing the Citation was Ali's, its an old Jetwelt kit, I'm not sure if its still available.. http://www.plushaus.info/jetwelt_modell_galerie.html
there's this.. http://aviation-design.fr/?rc-jet-model-falcon-7xI'm guessing the Citation was Ali's, its an old Jetwelt kit, I'm not sure if its still available.. http://www.plushaus.info/jetwelt_modell_galerie.html
A couple of K-45's would work out beautifully in the frankel Lear jet. They are just under 3 inches in diameter.The frankle design was kind of on the heavy side anyway so 18 pounds of thrust wouldn't hurt it.
$1,650.00
KingTech G series, a true Fuel Start turbine, will start and run on Diesel, Kerosene and JetA. G series have both solenoid valves built into the front cover, with a single fuel feed that eliminates at least 8 fuel connections upstream to the turbine, making a clean engine install a very simple task.
KingTech K-45G turbine engine, made in Taiwan
Specifications:
Diameter: 76mm (2.99")
Length: 195mm (7.68")
Weight: 700g (1 lb. 8.6 oz. )
Max. RPM: 162000
Thrust: 4.5 kg @ 15° C ( 9.9 lb @ 15° c )
EGT: 700°C max
Fuel consumption: 155 g / min ( 5.46 oz / min )
Fuel: Diesel, Jet A1, Kerosene
Lubrication: 5%
Maintenance cycle: 25 hr USD300
K-45G Engine Test by Radio Control Jet international Magainze Aug/sep 2015
My Feedback: (57)
My Feedback: (23)
Paint job was nice from a distance, other than none of nacelle stripes being lined up due to them putting all the thrust reverser clamshells in the wrong spots....
My Feedback: (7)
That ebay address is closed now. Was really hoping on something like Ali's as in CJ2 Citation with straight wings. We call them "slotations" in full scale but I think that would be great for the RC world. Frankel's Lear is another option except I'm not a really good builder. I'm an "assembler"! Went to that website and it said, "turbine version will be available in 2003". Wow...
ebay address is still working perfect .....
If it is not working for you please go to
www.ebay.de and type 231790295733
into the search field .....
BTW: We can build it for you .....
My Feedback: (7)
Don't know what I'm doing wrong. I thought it was my work computer so I went home and tried on my iPad and still get this.
But that Lear is the type I'm talking about.
EDIT. Just got it up and running now. Thanks.
What sized turbines? Looks like a beautiful kit!
From your pic the mistake is that you are still on ebay.com and not on ebay.de
two engines from 13 up to 22 lbs ...
Manufacturer contact info ...
AS-COMPOSITE
Sitter Alois
Bieretäckerstr. 26
94124 Büchlberg
Deutschland
[email protected]
https://youtu.be/5hFtXyI9Za4
AS-COMPOSITE
Sitter Alois
Bieretäckerstr. 26
94124 Büchlberg
Deutschland
[email protected]
Tel: 0049 8505 / 2892
Mobil: 0049 171 / 2625954
