RCU Forums - View Single Post - Painted wing, stabs and advanced graphics
Old 01-18-2016 | 11:27 AM
  #215
Portlandflyer
Originally Posted by scratchpc7
Good day Pat,
just so you know, you've inspired me. I look forward to getting going on this. Took an old 3/32nd wing skin that I will never use, sanded smooth, then filled with the lightweight spackle and sanded as well. Then put on some xxxspan that I had with polycrylic and getting something that I can try out with. Picked up some Wicked colors from hobby lobby, and looking to get the airbrush soon. So I am on the way. And yes, you are right, not too many people will put forth the effort but I will be one of them.
Not sure on the silk/poly span that I used but it was 13 grams for two sheets, about 33" by 24". there does seem to be a technique to putting that one, but one more thing to learn. Probably my first plane to try this all out on will be an AR6 Q40 plane that I am building the wing for. It will have to be glass because I need the strength on the outside of the wing; but I can still employ these techniques anyways.
Here is a place that has some vector drawing to download, so that may limit a step for some.
all-silhouettes.com
Doug,
The last Austral graphic that you painted, what is that font name? I've never seen it but I like the way it came out. I would love that for my NMPRA numbers, especially painted.
Doug
Doug,
Glad you are enjoying the journey.
I hope I still have the name of the font as once it's converted to a vector file I don't know what it is. It is one of the fonts in Corel Draw. It's the same one I used all over the plane. I just keep making different sizes of it. I will check later and let you know.
