RE: VectorFlight 300s, anygood?
Ok guys:
Help me out here, I'm awaiting the 66 inch 300, I have a .91 2stroke it weighs in at a whopping 1pound 15ounces. VF says that this plane weighs in at an all up weight of 8.25 with a .75 motor but does not indicate if this is a 2 or 4 stroke or what brand.
My supertiger .75 is just 4 ounces lighter than my .91 tigershark.
Does anyone have a weight on this plane without a powerplant mounted?
Does anyone have an opinion on flaperons with this plane?
should I mount the fuel tank on the CG or in the front at the fire wall?
Is there room for a smoke system?
Is there any way reduce weight in the air frame?
What about moving the elev and rudder servos to the rear?
Is it set up for a single or split push rod for the elevator? or is the elevator one or two peice as it comes.
Is the tail wheel designed to mount in the rudder?
Miloh.
