RCU Forums - View Single Post - Painted wing, stabs and advanced graphics
Old 01-19-2016 | 12:27 PM
  #227
Portlandflyer
Originally Posted by Smooth Pilot
PAt,
You indicated you use a plotter to frame out your masks. What plotter is it and can you give the approximate cost? Really liked the work you have done and I am starting a new build (Lightning pattern plane by Jeff Corder) and may incorporate some of your process.
Thank you,
Sheldon
Sheldon,
I covered the cutter I use at the outset of this thread, but here it is again.
Both of these will do a great job
http://www.uscutter.com/USCutter-MH-...n-Cut-Software
http://www.uscutter.com/USCutter-SC-Series-Vinyl-Cutter
Don't let the low cost turn you off. They are very good machines with great support.
The Lighting is a great airplane. I know Jeff and in fact he is following this thread. I also fly with his dad.
