Originally Posted by
billdor
Can anyone tell me how to use the wing adjusters on this bird? There is a small screw with a nut on the bottom in front of the wing pin and a larger screw with a lock nut on the bottom to the rear of the pin. I assume that one of them is for adjusting and the other is to lock it but I am not sure which is which.
Bill
Bill
The adjusters are similar to the Gator that F3AU sells....you turn the screw and the pivot moves. BUT, the included adjusters may need some freeing up as mine did. Then the nut should be locked onto the screw with loctite. Obviously you don't want the nut to come loose as you turn the screw. To
