Originally Posted by
Ricardo M.
PF, I had read the entire thread several times to “study”your painting technic wich is awesome and very inspiring. I have a couple of quetions.
1- Did you use any kind of primer on the fucelageprior to aplly the base coat? If so which one.
2- The other is the clear coat. Which product didyou use?
Thank you very much.
Ricardo,
I use only a little bit of primer on the seams that always need to be filled and sanded smooth. I used Klass Kote white Epoxy primer, but there are a lot of good ones available. PPG makes a good one for fuselage work.
I am just getting ready to shoot the clear. I have been using (and like) House of Kolor Kosmic Uethane Show Klear. Excellent product with great clarity. Clarity in clear coats is something a lot of guys don't take into account. Most guys think clear is clear,,,,but it may not be all that clear!
http://www.coastairbrush.com/products.asp?cat=756
