RCU Forums - View Single Post - IBU2 Pro problem
Old 01-22-2016 | 10:52 PM
47flatfender
Originally Posted by scooter_it
hello 47flatfender,
in my opinon i suppose the RX to IBU2 cable connected to CH1 (throttle) is faulty, if you have a Ohm meter available check the white wire.
In case the problem is this (i'm 99% sure about) you will need to match again the board with TX since the calibration done with missing channel signal (same as a faulty cable) will not work.
Regards
Ivano
Hi Ivano,
You were absolutely correct. I checked the signal wire with my meter and it was bad. The connector on one end had been crimped over the wire's sheath and didn't make contact. I crimped on a new connector and then calibrated the system again and it worked perfectly. I had actually swapped cables around yesterday to test them but I didn't think to re-calibrate the board and therefore got the same result and then wrongly assumed that a faulty cable couldn't be the problem. Thanks for solving my problem because now I'm excited to fine tune my installation and start enjoying this wonderful board!
CJ
