RCU Forums - View Single Post - Taigen Panther
Thread: Taigen Panther
Old 01-25-2016 | 09:17 AM
YHR's Avatar
YHR
inside this is a typical Asiatam torsion bar insert. I had to change the battery position, and mount the battery standing on its narrow side to allow room for a 3" Visatron speaker
All the electronics were removed and then reinstalled with all the electroinics in the front of the tank. This has a 15 watt amp and power invertor to drive the amp with 12 volts
Taigen have the power switch and volume control on the bottom of the tank. I wish they would rethink this. These European ones also have a charging port wired in( Located underneath the rear end tool box)
Also I added vacuum formed plastic gear housing guards to keep the lube oil out of the rest of the tank
