RCU Forums - View Single Post - Charging question
Old 01-25-2016 | 03:41 PM
Rodney
Originally Posted by geeter
I just use nimh ray-0 vac 2000 mah rechargeable battries from wal mart etc. they work fine using my spektrum . 4.8 volt charger. You can use and old futaba charger also. Just switch the leads so plus is on the inside. Because futaba plus is on the outside on the 4.8 volt side.
Are you sure, all my Futaba chargers have the outside shell as the ground or negative terminal. Spectrum is the only one I know that has the outside shell as positive.
