Originally Posted by
Dusty Steppes
Looks good! I'm always looking for ideas of what and how things get mounted inside. How many ohms and watts on that speaker and what did you use for the housing?
There would be 7 watts going to this 8 ohm speaker, The housing is an old empty packing tape spool. Works good with these speakers in tight installations
The owner uses an acoustic smoke machine so the extra room will be filled up with that installation, and that is why it was imperative that I found a spot for the electronics up front. The acoustic smoke machine speaker will be hooked up to the the other side of the amp
