Originally Posted by
P51Joe
A great builder friend of mine took the front tank and took 5" out of the middle and then put a divider from front to back and made two tanks out of one. Each engine will have two tanks to run off of. The front holds about 45 oz each and will drain first and then to the main tanks (saddle tanks). This will keep the fuel that is left close to the CG on the landing. I will have about 1.25 gal for each engine that will give me a good 6 mins. of flight with plenty of go around fuel for a landing.
Thanks, Joe.
I've been wondering what to do, I'm leaning on the side of going with three tanks and 2 UATs. Plumbing both UATs to the one center tank. Is there a reason not to do this? It seems it would be the best option as either motor would be able to use that center tank as a supply. I was thinking of adding two high-flow clunks to the main tank.
Also, in the case of a flame out, I would not have 1/2 my fuel supply stranded.
LMK.
sc
