Originally Posted by
jstanton
I have the CMP Zero with an EME-55 engine in it for power and it fly's great. I still had to add 1lb of weight to the nose to balance the plane. If you get the CMP Zero mount your elevator & Rudder servo's in the fuselage that will same some weight. My Zero weigh's in at 20lbs 2oz. Others that have built the CMP 80" Zero weigh is around 23 to 25 lbs. Will the EME-55 engine and a Xoar 22x10 prop the plane pulls in 26lb of trust. Not bad for a 20lb plane.
I have a Bob Holman/Don Lien i am selling if it sells i will get the CMP Zero.
