Not only is it working but working well. On one of my dirty passes I got into the throttle and didn't pick the gear up as fast as I normally would and thought to myself no way the mains could have worked. After the turn flying down wind to my surprise all 3 legs where up. So clearly all the problems getting it up are volume issues. Give it more volume and it will work fine.
On the last few flights I had last weekend I didn't even worry about the gear anymore and did nothing special in flight just took off balls to the wall and hit the switch. Worked fine.
