RCU Forums - View Single Post - Question for the 18MZ Guru
Old 02-05-2016 | 01:46 PM
SushiHunter's Avatar
SushiHunter
Default Question for the 18MZ Guru
I'm in the process of programming a new Habu 32 into my 18MZ but running into a slight issue. My question is why is the Aileron 2 not in a box like the rest of the control surfaces? I had a similar issue about two years ago when I was attempting to program a flying wing with elevator/aileron configuration. How I remedied that situation is I had to choose a wing type that was actually not correct for my application. That's what is causing me this issue now with my current Habu 32 programming. I've chosen the correct main wing type for my application, which is a separate channel for each aileron servo (#1 & #6) and with one channel for both flaps. The first picture shows the "functions" screen. The second picture shows the D/R screen. I need the aileron 2 to appear with a box around it so I can click and open it to do the servo programming. Anyone have any idea why aileron 2 doesn't have the box around it? Thanks
ID:	2145460   Click image for larger version
