RCU Forums - View Single Post - Tiger II mods and Engine choice
Old 10-21-2003 | 10:06 AM
GoMike
Default RE: Tiger II mods and Engine choice
Hey flipstart, here are mods I did on a TigerII kit last year. Flies like a dream.
Mounted the engine sideways (OS FS70).
Cut off the front fuselage "cheeks" and installed a balsa engine cowl similar to the Ultra Sport 40.
Glued the fuel tank hatch to the fuselage for front-end strength.
Reinforced stabilizer and fin trailing edges with hardwood strips.
Made symmetric, open wing tips. (sheet wingtips braced top and bottom).
Added ½ inch to the rear of the rudder.
Made it a tail dragger: Moved main landing gear blocks in front of the wing spar and angled them forward, placing the axles under the wing's leading edge.
Fabricated & installed a tail-wheel setup similar to the one used on my Ultra Sport 40.
Countered the extra 4-stroke engine weight by placing the battery behind former "C".
Knocked 1/2" off the recommended dihedral.
Replaced the aileron torque rods in the kit with 1/8-inch torque rods from the local hobby shop - inserted them deeper into the ailerons and epoxied them into the ailerons.
--Mike--
