RCU Forums - View Single Post - Question for the 18MZ Guru
Old 02-08-2016 | 01:53 PM
Malcolm H's Avatar
Malcolm H
Originally Posted by SushiHunter
Great information. Thanks guys. But how about the way that I have the rudder 1 and rudder 2 setup on the screens. I basically have the rudder in the tail set up on one channel and I have the nose steering in the front set up the "rudder 2" on separate channels. I do this so I can fine tune the steering (tracking) without it effecting the position of the rudder in the tail. Why doesn't this occur with the rudders like it is doing with the ailerons? I'm attempting to try out some "crow" settings. I'll play with it tonight.
Because when you selected your wing type as a 2 servo wing, you loaded a pre-configured program which maps all your basic aileron 1 settings onto aileron 2. With your rudders you have set up a program mix yourself. Don't forget to make the mix active with your gear switch in the down position so that the steering is switched off with the gear retracted.
Check out the Airbrake function to set up your crow. It will automatically apply the settings to both aileron servos because you've selected a 2 servo wing.
Malcolm
