RCU Forums - View Single Post - Question for the 18MZ Guru
Old 02-09-2016 | 10:55 AM
SushiHunter's Avatar
SushiHunter
Originally Posted by DrScoles
Sushi, did you change the ail 2 and give it a control? I think it should be nulled.
Yes I believe I gave it a control. I'm trying to do it this way because I want to set the angles of each aileron up individually. In better terms, on the more traditional setups, when one aileron is moved during setup, the aileron on the other side of the wing will move in the opposite direction. I want to be able to fine tune each one separately. I'm getting a better picture now of how this is to be done on the system I'm using from the previous replies.
I'm curious how to establish connection to each specific servo. So far, when I go to set up servo throws and angles, both respond, one positive and one negative (one moves up while the other moves down). I've set up the servo's correctly through the s.bus system. I'll play with it some more later tonight. I do like the airbrake setup idea for crow but also interested to explore the other options as others have suggested.
