RCU Forums - View Single Post - associated rc10gt help.
Old 02-10-2016 | 06:16 AM
mattster1971's Avatar
mattster1971
Originally Posted by etirado6713
So i have been out of the loop for a bit as i have had a change of hobbies due to time. However i am getting back into the rc world and bringing out an old but still fun RC10GT. I still have the original AE.15 nitro setup it came with out of the box. I have done a tear down and refresh one time however not to the point that i replaced the sleeve or any of the internals for that matter. Basically a good old WD40 and relube a while back. Just recently after taking it out of a closet i decided let me see if this thing still pulls. As im sure you all assumed the motor wouldnt pull. Being in the automotive repair industry and taking my fair share of 2 stroke motors apart in other instances i am more than capable to do any of the necessary work to get this thing running again. My major issue is PARTS!!! As most of you know this truck is from around 2004 aprox. I have owned it since it was new and never had any issues with it other than the plastic control arms and rear shock tower that i swapped out with aluminum and carbon parts. Back to the main reason for this post. What reccomendations would you guys have to get this thing back out on the track. Motor swap or rebuild the AE.15?
Why are you rebuilding the 15? is it corroded on the interior? I would dismantle it and see if you have corrosion. If not lube that puppy up and let the carb soak in alcohol or run alcohol through the intake port repeatedly, then drain it all out, and lubricate the piston and the internals a little. Then get to starting it. The alcohol will dissolve any deposits that are making it hard to start or not draw fuel. If the piston and the sleeve are deteriorated or seized permanently then its time to invest in a new engine.
