RCU Forums - View Single Post - Dual Elevator Setup..Help!
Old 02-12-2016 | 07:11 PM
B.Day's Avatar
B.Day
Here's another option. If you have one servo reversed on your transmitter it will be a little different from the other. Set your transmitter both to standard and use an inline servo reverser. t
This will drastically reduce the problem but you may still notice a little difference. However it should not be noticeable when you are flying because you don't operate your sticks the same way when sitting as opposed to when you are flying..
