RCU Forums - View Single Post - FB Viper build!!!!
Old 02-14-2016 | 04:05 PM
JoeJr1485
So I'm about to coat the turbine area with heat shield paint. What is the best or recommended cleaner to ensure the inside is clean? do you just use a wet cloth or do you use something else to make sure its clean?
trying to find out what cleaning agent or solution to use inside the fuselage. I want to start putting on the heat shield paint but want to clean the inside first. What are your recommendations?
