Originally Posted by
gunradd
Must have been a change then Dave. Mine fell out in pieces. I only have one that I could even measure to get the new ones. They are toast.
SC you have the good ones! They will work fine. Just make sure you install the ply wood brace that I copied from Mick. I was doing landings in a 90 degree cross wind over the weekend and the gear did fine. Before it would have been knocked out for sure.
Kris,
When you have a moment, would you mind sharing with me the overall weight, thrust and burn-rate for the K-300 which is scheduled to debut soon? I've specifically bought only Jetcat turbines and was not able to pull this off the KT site. I'd like to run some numbers on my end.
Thanks in advance.
sc
