Hey Keith, I was having the same issue with the screws being too small for the holes so when I talk to Catherine at FB she informed me that they are supposed to be screwed into wood blocks. I informed her that in the build manual it doesn't state that and they didn't supply the wood blocks or parts for it so I had to make my own. If you add all the small screws up 8 per servo it comes out right. two for the blocks to plate and two for brackets to block. What I did is I placed the servos on the plate then measured what size I needed. I hysoled one side and put them in place with the servo sitting on top so that I get the correct distance needed. I wait to dry then drill holes from the plate to block, insert screws. Once they are done I will take another picture.
