RE: Engine Problem
how old is your fuel?
i am doubting that it is a piston/sleeve problem, since that usually occurs gradually not immediatly. u would have seen that coming, unless u did something drastic to the engine, such as over rev it, or over lean it.
do u know anyone with a starter box? it would help, rather than yanking on the cord 1000 times.
u said that u have checked the new plug u put in? sometimes its the glow starter thats bad. check to make sure the plug is glowing brightly.
after that - make sure u can answer yes to the following questions:
my glow plug glows bright and hot
good, new fuel is getting to the carb, i can see it.
at idle, my carb is open about 1mm
my needle settings are correct.
thats it. if u have fuel, fire, air, compression, and the right fuel/air mixture - it WILL start.
