Yes, there should be no problem setting up your servos, linkages, end points and dual rates . If you are just getting a 2.4 module (and receiver) for your existing transmitter, you should be good to go. If you're getting a new 2.4 transmitter, you will need to input the same sub trim, end point, and dual rate info into the new transmitter.
