pre-setting servos? >
pre-setting servos?
pre-setting servos?
Old 02-28-2016 | 04:46 AM
Question pre-setting servos?
my plane is built. I'm waiting for my 2.4 stuff. Is it possible to set up the servos etc. on a 72 frequency.The question is when I transfer over to the 2.4 system ,will the same parameters be intact or will I have to reset everything again after installing the 2.4 system. I'm just bored and want to have it all set-up when my 2.4 stuff arrives. This is going to be my first 2.4 unit.
TAZZZZ
Old 02-28-2016 | 06:26 AM
Moderator
If you are talking about just getting the servos centered, yes you can do that with any radio and they'll be very close to the same when you change.That's assuming there is no sub trim or regular trim inputted from your transmitter.
Old 02-28-2016 | 06:50 AM
scale only 4 me's Avatar
My Feedback: (158)
TAZZZZ
What do you mean by transfer? you'll have to set up the new transmitter, or are you just adding a 2.4 module/RX to a FM system,, not sure what you're asking here
Old 02-28-2016 | 06:59 AM
Yes, there should be no problem setting up your servos, linkages, end points and dual rates . If you are just getting a 2.4 module (and receiver) for your existing transmitter, you should be good to go. If you're getting a new 2.4 transmitter, you will need to input the same sub trim, end point, and dual rate info into the new transmitter.
Old 02-28-2016 | 07:07 AM
thanks for the comeback. Ive got a DX7 (comes with receiver) on the way. ill just have to set up the TX. just trying to save some time so when they arrive then all I have to do is set up the TX. thanks again.
TAZZZZ
Old 02-28-2016 | 11:45 AM
Just be sure the TX is centered, then be sure the new one is also centered and go from there . ENJOY !!! RED
