RCU Forums - View Single Post - FB Viper build!!!!
Thread
FB Viper build!!!!
02-29-2016 | 10:02 PM
39
JoeJr1485
Dec 2015
470
Germany
Okay so I am a dummy. Keep in mind this is my first Turbine build so please bare with me. I wasn't thinking that I needed to sand away a little of the tail bulkhead to slide in the SS pipe. I didn't realize that the tale cone also holds the pipe in. So I cut away just enough so that it could slide in. I could have done that in the first place and not broke on of the fasteners off that holds the bottom hatch on. Well I'm learning. Now that I have it in. I have to play around with the placement of the pipe and the turbine. I did notice that in order to have the pipe flush with the tale cone, I have to place the turbine pretty much in the intake duct. Does this look right or is there supposed to be some pipe hanging past the tale cone? Please see attached pics. Also I need to make some mounting rails for the turbine but not sure if I need to place then behind the carbon rail or just put them on top then the turbine on that? When looking at centering the turbine with the pipe, the turbine needs to sit right on the carbon rails. I need help please to figure this out.
Reply
Like
JoeJr1485
View Public Profile
Send a private message to JoeJr1485
Find More Posts by JoeJr1485
View iTrader Profile
