RCU Forums - View Single Post - FB Viper build!!!!
Old 03-01-2016 | 10:04 AM
  #41
JoeJr1485
Originally Posted by FenderBean
Hey Joe, I sent you a message but it looks like you figured out the pipe. I told you the wrong info, the turbine rails come with the SM jet the FB uses what you have installed. From the pictures it looks like your turbine fits just fine, as long as your screws have a few millimeters clearance from the edge of the rail your good.
Where did you get your wire wrap to protect the tail wires?
haha Hey Keith, Yeah I got it put in. I wish I figured out to sand the tail end before I broke one of the tabs off that holds the bottom plate on. I'm learning lol. I have to ply to fix it. I just have to get some carbon now. before I start screwing the turbine down I will me sure and make sure its centered and have a good amount of rail to screw into. To your question on the wire, are you asking about the snake skin loom or the white rap on the wire? It your asking about the loom, I got it from dreamworks. I used the 1/4 and have 4 wires running in it. one of the wires is for the tail light that I will add in soon. the white rap on the wire itself came on the wire already. Its PB wire. Does your PB wire not have it on there? I also ordered some loom from 1/8 to 1/2 from http://nolimitaccessories.com/?s=loom&post_type=product. it should be in this week. I got blue and red mix to match my paint. it will be in this week I hope.
