Originally Posted by
1sgt
I use nylon sewing thread to remove hatches. First drill a small hole to pass the thread through. I hold the tank deck between my legs. Pass the thread through the hole . On the free end, wrap it around a screwdriver and tape it. That will allow you to hold it( leave the other end attached to the spool). Then just slide the thread along in a sawing motion. Go slow so you don't melt the plastic or the thread. Every so often roll the screwdriver so your using fresh thread to make your cuts. You'll be surprised at the control and smoothness of the cut. It cuts so well that I throw the molded hatch in my parts bin, or like on my KT, use the same cut hatch to make it open.
Hope this helps.
Jim
This sounds interesting, I would like to try. I guess Im not following though, where do you drill the first pilot hole, in order to save the hatch? A video would be great, lol.
