RCU Forums - View Single Post - FB Viper build!!!!
Old 03-12-2016 | 11:41 PM
  #50
JoeJr1485
I have a few more things done. So I ordered the mini bulkhead fittings from DreamWorks thinking that they would be a little bigger than what they were so I couldn't use them on how I wanted. What I did instead was cut a piece of 3 ply and drilled the holes for all my airlines. I used hysol to glue it to the rear bottom section of the fuse. I have the tank supports in the bottom with rubber pads from DreamWorks on them. I am working on installing the air cylinders but still have to finish the tray to hold them. On Monday I will have the missing and replacement parts from FB. USPS didn't deliver it today . My wire loom will also be in on Monday! I am hopping the Esprit Models get a supply of the CB 200's in this week so that I can order one. I also need one more valve for the speed brakes.
I still have to order a new cockpit from FB but that will be at a later date. Here are a few more pictures. I also changed out the airline fittings to the wings.
ID:	2152294   Click image for larger version
ID:	2152295   Click image for larger version
ID:	2152296   Click image for larger version
ID:	2152297   Click image for larger version
ID:	2152298   Click image for larger version
ID:	2152299   Click image for larger version
ID:	2152300   Click image for larger version
ID:	2152302   Click image for larger version
ID:	2152303   Click image for larger version
ID:	2152306   Click image for larger version
ID:	2152308   Click image for larger version
ID:	2152309   Click image for larger version
ID:	2152310   Click image for larger version
ID:	2152311   Click image for larger version
ID:	2152313   Click image for larger version
ID:	2152314   Click image for larger version
