RCU Forums - View Single Post - FB Viper build!!!!
Old 03-15-2016 | 01:20 PM
  #57
JoeJr1485
Originally Posted by FenderBean
This is a place I always over do it, I really over do it on the vent side. I would suggest just using the bvm high flow fuel line, clunk line and even there hi/flow fuel tank fitting. As for air traps I have used MAP hi-flow and now use the interairco hi-flow. Just because they are clear and have easily replaced filters. BVMs hi flow will work as well.
Thanks Keith. I will do that then. I was looking at ultimate jets fuel tank fitting and hardware but I was unsure about it. I will look into BVM and get the pricing down. lol I was looking at the interairco too. I had seen that you had one and was kind of sold on it after seeing yours and reading the reviews. I will be ordering one soon from Chief. DreamWorks is out of stock and has been for a little bit. Another question, do I use the 6MM (3/16) tubing from tank to trap then from trap to pump and from pump to shutoff valve then a reducer Festo fitting from 6mm to a very short 4mm run to turbine? I would think that this would help reduce the flow restrictions. On anther note, I got some items in to almost finish up the wiring. I got the items in form FB and reinstalled the air cylinders and about to hook the airlines up. I am currently working and getting the equipment plates fitted and put in so I can start laying out my placement of items. Here is a few pictures.
ID:	2152764   Click image for larger version
ID:	2152765   Click image for larger version
ID:	2152766   Click image for larger version
ID:	2152767   Click image for larger version
ID:	2152768   Click image for larger version
ID:	2152769   Click image for larger version
ID:	2152770   Click image for larger version
ID:	2152772   Click image for larger version
ID:	2152773   Click image for larger version
ID:	2152774   Click image for larger version
ID:	2152775   Click image for larger version
ID:	2152776   Click image for larger version
