Originally Posted by
av8tor1977
I don't have a Homelite 33cc here to refer to to make you a prop hub. I've got one in storage about 200 miles from here but don't have access to it at the moment. Do you have your original magneto flywheel? I often make prop hubs using the center cut out of the magneto to fit the taper on the crankshaft, and then make a prop hub to fit against that. I then make a collar that goes around that flywheel center piece with a magnet in it, and it is adjustable for setting the timing. How are you going to mount your sensor, and do you have a pic of the engine??
AV8TOR
At 200 miles to get to your storage ,I'll bet you don't go there often.I go 17 miles one way to my storage area in an old movie theater and gripe about having to go so far.I make a list of what is going up and what is coming back with me,so I don't forget anything,but I usually do. I only pay $20 a month for a 10' x 12' space so I shouldn't be complaining about the distance.It also doubles as a work space in the summer,with a restroom,water,refrigerator and a microwave.
