RCU Forums - View Single Post - Lipo Chargers
Thread: Lipo Chargers
Old 03-17-2016 | 06:47 PM
Zeeb's Avatar
Zeeb
My Feedback: (41)
Originally Posted by KC8QPU
Why would you want to charge through the balance leads??? I would also assume that you are looking for one with a built in small power supply to you can just plug it into an outlet?
Most batteries with "factory" type charge/balance leads, the balance plug wiring is short. Then you have to disconnect the main battery output to charge them so you have two connections you have to make and that's kind of silly in my estimation as the rx packs are so small. It also allows me to put the rx packs wherever I want and still be able to charge them because you can use up to a single 36" charge lead.
Now mind you; I do NOT do this with LiPo packs but virtually all of my models have two cell A123's for rx packs so removing them from the model to charge isn't necessary.
