RCU Forums - View Single Post - Caelus - build and test flights
Old 03-21-2016 | 09:16 AM
Zippi's Avatar
Zippi
My Feedback: (10)
I have to agree with you, the pics do not do this plane justice. Did you buy the motor mount from F3AUnlimited or are you going to make your own? Here are a few things I ran into during my build. About (3) of the pre-cut slots for the control horns were not in the correct place, the right landing gear had the (2) holds pre-drilled in the wrong place, a lot of the screws in the bag I replaced as the threads were not very good, some of the needed hardware was missing, Mike M. sent me an allen wrench to fit the very small screws for the tailwheel assembly. You will have to cut the cooling vents in the front and bottom of the fuse, the slots for the servo arms to pass through the bottom of both stabs, and the slots for the pull pull rudder cable to pass through both sides of the fuse. None of this was a major problem but to some it may be.
