RCU Forums - View Single Post - Balsa nose cone construction
Old 03-23-2016 | 06:02 AM
CK1's Avatar
CK1
My Feedback: (60)
Originally Posted by R8893
A less expensive alternative is to carve and sand a foam block to shape and cover with fiberglass and epoxy. Then you want it hollow you can cut out the foam and finally dissolve the last little bit with many solvents including gasoline.
+1 Foam is the quickest and easiest way to get the form you want .
