Originally Posted by
josser9
I see other r/c brands have servo horns that are metal/titanium but im not sure if they would fit my servo, are all the servo gears(the gear that horn/saver slides onto) universal or do they come in different sizes?
You have to count the splines (teeth) on the top of the servo to find out what will fit. Some servo horns will have a mark on them "F"(Futaba) 25 teeth, "J", etc. etc. 25 tooth count is a common spline number with servo horns that is needed. Hitec servos use 24 tooth a lot of times and Airtronics/Swana stuff uses 23 tooth horns in general.
