RCU Forums - View Single Post - Great Planes Sequence 1.20 Build Thread
Old 03-30-2016 | 04:03 PM
  #68
rodney tanner's Avatar
rodney tanner
[QUOTE=X-30;12195038]Hi Rodney,
I have two 4s batteries moved back as far as they can go without doing any modifications. I also moved my receiver pack back. This combined with an improved tail wheel puts the CG just where I want it. I did not move the rudder servo back, but there would be no harm in doing that. My 4s 4000mah batteries are a little on the heavy side at 417 grans each. The total weight ready to fly is right at 10.5 pounds.
I’m pulling 80.8 amps/2410 watts on takeoff and in the air the prop unloads down to 70.0 amps/2160 watts full throttle.
X30
Hi X30
Many thanks for the info.
Prop - APC 18x12?
Motor Mount for the A60 5s
I saw you posted a mounting shot on RCG.
The x mount is behind the fire wall.
How exactly did you mount the bind nuts?
Could you post your box assembly steps/tips with a pic if possible?
Many thanks in advance.
