Hanger 9 P-47 150 servos
I just picked one up and have a couple questions about servos. The retracts call for a specific servo, but at $60 each and they only work at 4.8 volts, those wont do. I would have to make a separate power supply just for those two servos since I use LIFE packs for the RX. Does anyone know if the TS-63 servo will work? Its a 6V servo. For everything else, I plan to use the AS50 MG servos from Hobby people. Been using them in a few planes without any problems, just trying to find out what arms fit them.
I am also going to use a DLE30 on it and found it sticks out an inch further than what is called for, its 6 1/2", manual says 5 1/2", Should I open the firewall up to stick the carb in that extra inch, or will it be OK having the prop out that extra inch?
