Originally Posted by
Bubblehead575
Brenner
The bearing and grommet in the rear motor mount (shaft support) came out in flight. Have you seen this before and what is the fix. Is there an alignment problem or do I need to put a few drops of CA on the grommet when I install it? I reached out to Mike at F3A for a replacement.
We have had one other instance of this happening. The solution is to us CA to fix the needle bearing into the grommet.
Send me a private message with your mailing address, and we'll send you a replacement bearing.
Brenner ...
