RCU Forums - View Single Post - Classic vs Ultra Lightning
Old 04-11-2016 | 06:52 AM
  #34
asimace
Originally Posted by scoeroo
Is the minor up elevator position for neutral flight an incidence issue ?
Is it worth shimming the tail feathers ?
You cannot shim the tail plane as it has to sit tight against the fuselage otherwise the bottom lid will not close properly.
It has all been factory alingned and it's not worth changing anything.
Really it's not a problem, the UL flies perfectly inverted and knifeedge without any mixing.
Mauri
