Originally Posted by
slskn
.....just wondering if anybody knows if Nitro goes bad ...........
Not in the sense of goes "bad". If you kept it sealed up well then it should be fine. I have burned 20 year old fuel cans that were well sealed but I did mix it with fresh to insure quality.
Remember that we are dealing with alcohol and nitro, both of which are VERY prone to evaporation. On a gallon of premix, if the ethanol or nitro manages to evaporate off over a period of time then you would, of course, consider that bottle "bad" because the percentage of oil/nitro/ethanol would be changed.
Sometimes this can be seen in a translucent gallon jug as a (unwanted) change in liquid level.
The up-side? The oil doesnt evaporate off, it will still be there so at least you wont HURT your engine.
I have noticed some of my newer gallon jugs that bleed out of their (bottom) seams while I have it stored on the shelf. Very disconcerting.
