Well finally got some time to work on it today. Tail is all hooked up and working well, Engine is mounted, and all I have left it to hook up the throttle, place the tank and hook up the lines, and mount the RX and switch. Battery placement will come after I balance. Then put the windows in and the fuse is finished. Wing braces are done, struts need doping, and all that is left are ailerons. Going to leave the cowl as it is for now until after I get some flights in with the used engine. If it flies well then I will open the cowl up and put it on. If it doesnt work, then I will look around for a twin for it.
Other than the rudder and the braces painted, it looks like the picture above, so no new pics yet.
